ritzdvb 0.8.13 الان بستار وherby اخيرا عملها بعد طول انتظار
neztiti
مستشار المنتدى
الجديد فيه
DVB-Application for DVB-Cards (XP/W2K only )
Supported Cards
- Premium-Cards:
SS1, Technotrend-Premium, Hauppauge Nexus (DVBs + DVBc)
- LowBudget-Cards: (Only tested by BetaTesters):
SS2, Pinnacle PCTVSAT, NOVA, TT-DVBc-Budget and Twinhan 102g/1020/1030A
IMPORTANT: RitzDVB comes WITHOUT any codec-setup for LowBudgedCards.
That means: If you have a LowBudgetCard you need working dvbcore-xgr-graphs which are based on registered codecs on your machine. The new AddOn-Wizard include some graphs, but as said the corresponding codecs are not included. (see manual chapter "LowBudgetCard HowTo" and "Other Remotes as SS1-RC5" for further Info about LowBudgetCards)
I wrote this application to watch&record for myself, so please do not write Wish or Bug Lists.
If you like my program you can use it, otherwise consider trying other dvb applications.
Features:
- Record/Play-Modes: PVA (Premium Cards) + MPEG
- Hardware OSD over Premium DVB card TV-Out
(EPG/Channel list/Play & Record Files/Timers...)
- Channel editor included
- Language editor included
- Scheduler included
(with automatic Shut Down)
- Soft Remote included
- Original SS1/TT/Hauppauge-NEXUS/NOVA Remote supported
- for all other Remotes Girder-File included
- MD-Plugins supported
- Channel logos supported
- tvtv Joblist Support (generate Timers online via web)
- call extern Executables
- orig. SS1/TT/Hauppauge-Nexus CIModul supported
- Support Multiple DVB-Cards
- DiSEqC1.2 Support - Tested only with SkyStar1 and SkyStar2(modified drivers by MiBi)
P.S: Thank you Saar, and everyone who developed DVBcore !
1000 Thanks to Saar for permission to make it public.
RitzDVB FullPackage 0.8.1.3 - List of new features
RitzDVB
Full Firebird migration:
new: A second Database MAIN.fdb was added which now includes Channel list, Favourites, Timers,..
The old formatted files channels.dat and FAV.dat, which you'll still find in db folder too, are now just mirrored files. These mirrored files in the db folder are automatically generated files from the Main-Database and are used for fallback if someone drops the main-database.
If you have some old formatted RitzDVB dat-files that you want to migrate into RitzDVB_0.8 you have to copy these files into the new "db\import\" folder. Only dat-files located in this folder will be imported and migrated into the new RitzDVB database format by next restart of RitzDVB.
Channellist:
new: Completely new redesigned Channel list in Main window and EPG
new: Free grouping, ordering, filtering, sorting, layout style of the Channel Tree
Channeleditor:
new: Completely new redesigned Channel editor
new: Channel logos can now easily assigned/imported/updated inside the Channel editor
new: The new Grouping feature allows for simple deleting of whole Channel-Groups (e.g. group by a column of your choice, then select a group and press delete to remove all channels associated to the group
new: The Channel type (TV, radio, data, TV crypt, radio crypt) is now a new column that can also be used as grouping criteria
new: capability to create self-written filter-criteria
new: ...and tons of additional new features you will simply find, by playing with the new Channel editor…
Languag editor:
new: Completely new & redesigned Language Editor
Scheduler:
new: New: Support of recurring (repeated) timers
also the SendMsgToRitz param TIMER: was enhanced to include recurring data (see manual of SendMsgToRitz in folder \help)
Customizable Grids:
new: under Options->Layout you can customize Layout of Editors, Channel list, and EPG to your own wishes. Don’t forget to save the Layouts as a file if you want a static change after the next restart.
new: in the Channel list of the Main window and the EPG window you can create your own groupings, sorting, hiding of columns, and ordering of columns to your own wishes in the Tree of Channels. Don’t forget to save the Channel list settings for a static change(with right Click Menu). Please take care that the grouping & the sorting criteria are not saved in the predefined fixed Groups. Only in the "Custom Grouping" option will it save your personal group & sort criteria’s.
MISC:
new: Quick info EPG grabs data as first from database to increase time of request
new: Record File is now in shared status. means it can be played by e.g. VLC Player during recording.
new: PID recorder
SendMsgToRitz
new: recurring timers can also be created via SendMsgToRitz (see manual in help\SendMsgToRitz)
LogoFileMaker
DROPPED: Due the enhanced features of the new Channeleditor inside RitzDVB there is no longer a need for the external tool LogoFilemaker. Channel logos can now be assigned easier in the RitzDVB Channeleditor.
http://www.ritzdvb.com/forum/pafiledb/uploads/RitzDVB_0.8.1.3_FullPackage.zip
ysr
ما شاء الله على التحديثات الرائعة
البرنامج قبل التحديث كان رائع على الرغم من بساطته
والتحديثات يا جماعة جاية بالجملة وفيها كتير مفاجأت
تشكر يا عم نزار على التحديث
achour
يا اخوان هل يفتح المشفر ويدعم الشيرنغ عن طريق الجيبوكس والنيوكامد؟؟؟
بارك الله فيك يا اخي العزيز وان شاء الله تكون في ميزان حسناتك
thumb: thumb: thumb:
alioite
achour قال:
نفس السؤالlol
ah_aj16
تسلم ايديك حبيبي نزار
اما بالنسبه للمشفر فيتعامل معه كالمايثيتر يدعم الشيرنج وكل الادوات الاخرى والبرنامج روعه
waleeo
رووووووووووووووووووووووووووووووووعه وبالفعل شي تمام وبارك الله فيك يامدير الموقع ..... على هذا البرنامج
والمزيد من التقدم والرقي يا استاذ نزار
DVB Master
ألف شكر ليك يا كينج التحديثات , وجاري التجربة بس بعد الإمتحانات إن شاء الله
achour
ساقوم بالتحميل والتجربة
واعطيكم اليقين
مرة اخرى مشكورين على التعاون
hany3h
يعطينى رساله كلما وقفت على احد القنوات
TPInifile not found
ما معناها علما بانى مش عارف اعمل له ملف جرافك هل ده السبب
hany3h
خلاص حليت المشكله دى البرنامج كان عاوز ملفات ini للترددات
لكن المشكله اللى مقبلانى دلوقتى عاوز ملف جرافك يشتغل معايا انا مبعرفش اعمل ملف جرافك
emadalzouk
الف شكر يا نزار يا عسل دائما ما تتحفنا بكل ما هو جديد تشكر صديقى و سوف اقوم بالتجريب الان
abuahd
ما عاد فيه ألفاظ توفى جمايلكم وجهودكم الجبارة الا الدعاء لكم ولمنتدياتنا الرائدة Stardvb forumsالتى علمتنا الكثير وال....وفقكم الله تعالى وحفظكم على الدوام
