TwinHan Problem
rumba
Hey All thanks all alote for this great fourms am a new user here and wish u all the best:ra:
i have a problem on my twinhan card:wall:
i have multi frequancy LNB connected to my both receaver , and my twinhan DVB card .that makes me able to watch my own channels as my family watching other channels on the same time ,i wish iam clear.
my problem is some channels have no signal at all on my DVB card when the receaver is turned off!
like rotana cinema , gear one , if i want to watch those channels on my pc i have to go and turn on my receaver!!oh:
i dont know why this happend
so any one can help me:confused:
thanks
Brave Heart
Hi ....
welcome to star DVB , i wish you all the luck , and i hope that you will enjoy it , your problem is with the polarity , the vertical and the horizontal , you must watch channels of the same polarity like your family watch , or those the LNB is set to at the moment . if you wanna get rid of it all , intert LNBs with dual outputs and use Disek 2.1 then youi problem will be solved completely .
:) :) :) :) :) thumb: thumb: thumb: :) :) :):) :)
rumba
i already have the LNB with dual outputs i think i said that , when i said i have multi frequancy LNB i meant
LNB with dual outputs :D any way , thanks for your help , but tell me what do you mean by using Disek 2.1
what is Disek 2.1?
i think that is not what i have :D
thanks alote
kofta
HELLO FRIEND...I think this problem could be happened from the low voltage output of the dvb card .
i`d like to tell u that problem happens alot for dvb cards users
since u turn ur receiver on so the lnp can get some power of the rceiver
i think the solution would be changing ur pc power supply to other one with higher amber output so it can make better work
rumba
thanks all for ur help i'll try to do what u all told me and c if the probems will go or what
thank all for ur care
ronaldinho1988
DalilORONALDINHO1988
