problem skystar2
fawz66
friends i have big problem after 2 or 3 hours working the card will stop working no signal and it will give SKYSTAR2 NOT STARTED so i have to restart the pc and sometimes remove the card and install again
any solution thanks
Frozen
any solution thanks
try this and do it step by step :
remove the Sky Star driver
turn off the computer
remove ur sat card from the slot
turn on ur computer then turn off again from the windows
set the card on another slot and be sure to get rid of the dust in the slot by blowing in it with a vacuum for example :ra:
then turn on the computer and install the driver ( installing new driver will be better
that's it
Mk4ever
monitor the temperature, too
u can use speedfan which will give u some temperatures from parts that have thermal sensors. Skystar cards don't have sensors of course, but from other temops, u can estimate.
Good luck
