Mpg2Cut2 v2.8.4 Build 9330 (2.8.5a)
didou
Mpg2Cut2 WebPage:
What is In this version:
* Output Parsing bug FIXED.
(I think !)
* Option to suppress unwanted audio trackss.
File - Save Parts.
* Better detection of Mpeg Audio frame heaaders.
Work still in progress.
* Fix calculation of Mpeg Audio frame sizee.
* Leadtek Overlay Key option.
If Leadtek Winfast is running in the background in silent mode, it stops Mpg2Cut2 from using it's own Color Key for the overlay.
Turn on the following option to force Mpg2Cut2 to use the Leadtek Color Key. MENU - VIEW - TECHNICAL - DRIVER CONFLICTS - LEADTEK OVL KEY Side effect is that Menus become transparent.
* VHS less ugly during preview.
2 options are available to help when previewing VHS sourved material.
These options do *NOT* alter the output file at all.
a) Luminance panel "VHS" option limits oversaturated red.
b) MENU - VIEW - SPECIAL FX - VHS Convergence.
Allows Color to be shifted slightly, relative to luminance.
* Regressed compiler maintenance.
My rebuild of the VC-6 environment under XP stuffed up the optimizer.
So I have gone back to Win98 for "Release" compiles, until I figure out what went wrong under XP.
I suspect the processor pack or one of the SP packs.
* Misc minor changes.
* *Warning for Panasonic DVD recorders :-
I still need to do a lot more work for compatibility.
E.g. Long clips still seem to have problems for some reason.
* *Warning for Satellite users :-
The Time Stamp correction option is NOT compatible with Satellite.
Lien dvbsupport:
Lien Rapidshare:
