اخر اصدار من برنامج
DVBViewer Pro V3.9.4.85 BETA
ولكنة يحتاج الى يوزر وباسوورد
والذي لدية اليوزر والباسوورد الرجاء وضعة في نفس المشاركة
[LEFT]Version BETA 3.9.4.85
- Change: USB CI: Handling completely rewritten. Should work with any DVB-Device / USB CI (Hauppauge/terratec) combination.
- Change: Channeleditor: right click selects the underlying entry.
- Change: Channeleditor: click outside the channellist deselects the last selection. important for export.
- Add: Channellistpopup: activate in options/TV+Radio. Do not use together with remote or Keyboard!
- Add: Action: Show Radio list=8265
- Fix: Under certan circumstances a exception did break the import of recordings into the database.
- Add: Added FMenuClickPercent to tweaks.txt
- Add: Timeshift filenames now contain the channel name.
- Add: OSD notice on toggeling keep timeshift On/Off.
- Fix: DVD Audio/Subtitle problem with preselected language/AC3.
- Fix: The trayicon hint now shows the filename on fileplayback.
- Fix: Graphrebuild and DVD playback didn't work sometimes.
- Several fixes and enhancements.[/LEFT]
