greatmagician
السلام عليكم
Driver Genius Pro 7.1.0.622 Portable
PHP:
Driver Genius can detect and quickly backup the installed drivers in system. It can compress the backup drivers to a zip file, self extracting file or a independent auto installer program.
Drivers Restore: You need not install drivers one by one after reinstalling Operating System. Just one click to install all your backup drivers automatically. You can also install drivers in command mode silently. If you need install drivers on multiple PC with the same hardware configuration, That will save your much time to reinstall system.
Drivers Update: Are you still using an old version or beta version drivers? Those faulty drivers always cause compatibility problem. They are the biggest hidden trouble cause system crash. A suitable drivers can upgrade 50% or even more performance of hardware. There are more than 30,000 device drivers information in Driver Genius Database including Motherboard, Sound card, Video card, Network card, Modem, Mouse, Keyboard, Scanner, Printer, Digital device etc. All you need to do is one clicking mouse, Driver Genius can find out drivers that need updating. All drivers we offer are official version or WHQL version, you can use them without any worries.
Drivers Uninstall: There could be some leftover drivers in your system because of changing hardware or updating drivers. Driver Genius can find out these useless drivers quickly and uninstall them.
LiveUpdate: We will update large numbers of drivers on our website. You can synchronize database with our website to get the newest version drivers by Liveupdate program
