مروان ساهر
Android Color Splash Effect Pro 1.5.5
<br>
<br>
<br>
<br>
<br>
<br> Color Splash Effect lets you quickly and easily give photos a dramatic look by converting them to black and white, while keeping your chosen details in color. This effect draws the viewers attention to the colored areas, creating striking images.
<br>Most selective coloring apps give you 2 painting choices: Gray or original color. Color Splash Effect gives you this PLUS the ability to paint nearly ANY color!
<br>The intuitive and responsive multi-touch user interface makes Color Splash Effect amazingly easy and fun to use. Use your finger as a brush to "paint" sections of your image black and white, or to bring back the original color. Zooming in and out using the two-finger pinching gesture allows you to work on details with pixel-accuracy.
<br>Features:
<br>- Share your edited images on Facebook.
<br>- Save multiple sessions to resume your work later.
<br>- Undo any number of accidental brush strokes.
<br>- An alternative view mode highlights the regions that will remain in color with a red tint. This makes it easier to see and adjust the boundaries between color and black & white regions.
<br>- Choose from 4 different brushes (hard or soft edged, opaque or transparent)
<br>- Work in landscape or portrait orientation.
<br>- Hide the toolbars in full screen mode.
<br>- Optimized for tablets
<br>- Pinch zoom(zoom with fingers)
<br>- Scalable brush size
<br>- Change colors of your photos
<br>
<br> Photos From The App
<br> http://picxat.com/image/GalleryImage/ZHrg6EDO/hBlBXs6rsP
<br>
<br>
<br>
<br> File5wap
<br>DOWNLOAD
<br>
<br> MegaUpLaod
<br>DOWNLOAD
<br>
<br> UpLoaded
<br>DOWNLOAD
<br>
<br>
<br>
<br>
<br>
<br>
<br>Features:
<br>
<br>
<br>
<br>
<br> File5wap
<br>DOWNLOAD
<br>
<br> MegaUpLaod
<br>DOWNLOAD
<br>
<br> UpLoaded
<br>DOWNLOAD
<br>
<br>
<br>
