تطبيق تقليل استهلاك البطاريه بنسخته الاخيره Battery Saver PRO v2.0.4 Android
رائد منير
<br>
<br>
<br>
<br>
Master your save battery skills & phone boost skills easily! This app helps users Save battery life with ONE-TAP by optimizing phone settings which functions as Memory Cleaner, App Killer, Task Killer, and Various Function Controller. On top of that, with Deep Sleep Mode Configuration - Normal / Smart / Advanced / Custom / you can easily change the Battery Saver Mode to prolong your battery life. App Consumption Mode geared as well, letting you understand which Application consumes the battery the most. Super useful battery saver widget, and many more features. If properly used, this app can save battery power up to 2x-4x more, boost your phone go lot faster! Yet, This app is Extremely Easy.
<br>
<br>
5 in 1 Toolbox Mix App! – One-Tap Optimizer including Memory Cleaner, Junk Cleaner, Task Killer, Functions Controller. Charging Mode - Track your phone remaining time. App Consumption Tracker - See which application consumes the battery the most. Deep Sleep Mode - Configure your custom saving mode with one-tap! And Super Easy Widget. 5 Features but its still VERY EASY TO USE! Download this app/widget, become a master of Android Optimizer!
<br>
<br>
Features:
<br>One-Tap Optimizer (including Memory Cleaner/Junk Cleaner/Task Killer)
<br>Cleans up Memory, Kills tasks with extremely simple one-touch "Optimize" button to save energy!
<br>Indicates how many hours you can save with one-tap. Defend your phone from drain!
<br>Sleep Mode Battery Saver
<br>Eventhough you are not using the phone, it syncs data every seconds that will drain your battery life.
<br>While not using your phone, set your "Sleep Mode" to save battery!
<br>App Consumption Tracker / Uninstaller
<br>Tracks and shows you which app drains & save battery life at certain level
<br>Choose the app that drains the most and Uninstall/or/Force Stop to save time!
<br>Remaining Time Tracker
<br>Indicates the remaining/limit time for Talktime,Game,Standby,AudioPlayback,MoviePlayback,WebSurfing,and Reading.
<br>Life level in percent (%) at status bar.
<br>Widget
<br>Access your Battery Saver Function from Home screen Widget
<br>
<br>
Whats in this version : (Updated : Feb 3, 2015)
<br>Fixed Crash on Lolipop/Android5.0
<br>Required Android O/S : 2.3.3+
<br>
<br>
Screenshots :
<br>
<br>
<br>
<br>
<br>
<br>
MediaFree
<br>DOWNLOAD
<br>
<br>lenfile
<br>DOWNLOAD
<br>
<br>up07
<br>DOWNLOAD
<br>
<br>turbobit
<br>DOWNLOAD
<br>
<br>letitbit
<br>DOWNLOAD
<br>​
<br>
<br>​
<br>​
<br>
