أحدث اصدار من برنامج الحفاظ
على بطارية جهازك الاندرويد
DU Battery Saver 3.9.5
أعود اليكم اليوم بأحدث إصدار لأقوى برنامج فى العالم للحفاظ على بطارية جهازك الاندرويد بتصنيف 4.7 فى متجر جوجل بلاى ستور واكثر من 25 مليون تحميل حول العالم هذا البرنامج الذى يقوم بزيادة عمر بطارية جهازك الى 50 % اكثر من الطبيعى عبر التحكم فى جميع التطبيقات التى تعمل فى الخلفية وتسبب تأكل فى استهلاك البطارية البرنامج اكثر من رائع ويستحق التجربة .
تاريخ تحديث البرنامج : 6/11/2014
Version 3.9.5.2 Updates
1. Upgraded OPTIMIZE engine, better saving performance
2. Brand new design of Notification
3. Bugs fixed
مميزات البرنامج بالانجليزية
PHP:
DU Battery Saver, the world’s leading battery saver & power manager, is a FREE battery-saving app that makes your Android battery last longer! Get up to 50% more battery life for your Android phones and tablets, with DU Battery Saver’s smart pre-set battery power management modes and easy one-touch controls that solve battery problems and extend your battery life. Over 600,000,000 people’s top choice among all battery saving apps!
Upgrade to DU Battery Saver PRO, and get up to 70% battery power savings!
< https://play.google.com/store/apps/details?id=com.dianxinos.dxbs.paid >
Highlights of DU Battery Saver power “doctor” & manager:
? Fast Battery Saver—Instantly find and solve battery problems with the ”Optimize” button.
? Simple Battery Saver—Use smart pre-set battery power management modes or create your own to get high performance and great energy savings.
? Effective Battery Saver—Protect your battery with healthy battery charging to extend life of your battery.
? Convenient Battery Saver—The “Optimize” home screen widget allows you to stop power-consumptive background apps with one tap to boost your battery life.
? Easy & Powerful Battery Saver — Extend your Android battery life by up to 50% without charging in different stages.
? Global Battery Saver—Supports 17 languages, including: Deutsch, Espaٌol, English, Française, Português, Português do Brasil, P??????, Türk, Bahasa Indonesia, Italiano, العربية, ???????, Ti?ng Vi?t, ???, ???, ??(??), ??(??).
? Adapts to You—Automatically save power and energy with DU Battery Saver’s Smart Power settings (requires DU Battery Saver PRO version).
Features and Benefits of DU Battery Saver Android power “doctor” & manager:
? ACCURATE STATUS—Smart technology helps you know exactly how much battery charge you’ve got left with a detailed analysis of your Android apps AND hardware;
? SMART PRE-SET MODES—Choose a mode that fits your energy usage, or customize to find the right balance of battery life and performance using our smart battery saver:
? ONE-CLICK OPTIMIZATION—Instantly find and fix battery power-consumption problems and unlock detailed settings to super-tune your energy savings;
? ANYTIME OPTIMIZATION—Manage background apps and your phone hardware easily and safely with our smart home screen widget (i.e. battery level widget, hardware switch widget, and mode switch widget);
? BETTER BATTERY DETAILS—View your phone’s battery power level by percentage or by time remaining;
? HEALTHY CHARGE MANAGER—Track and implement healthy charging practices in different stages to keep your battery working its best
حجم البرنامج : 6 ميجا .
الموقع الرسمى للتطبيق
http://duapps.com/du-battery-saver
رابط البرنامج على جوجل بلاى ستور
والان مع صور من داخل البرنامج الرائع
لتحميل البرنامج من جوجل بلاي
