برنامج دى فى بى فيور الشهير لتشغيل كروت الستلايت على الكومبيوتر بالاضافات الكاملة والبلجينز
DVBviewer Pro 4.1.1.1+Plugins
مكونات ومحتويات البرنامج
طبعا يا جماعة البرنامج فى بداية تشغيله بيطلب فك الحماية عن طريق انه بيتصل بالسرفر الى عامل البرنامج وضاغطه وضايف ليه الاضافات
انا جربت اعمل فك الحماية ليه من مصر قالى ان العرض غير متاح فى المنطقة
فياريت الى عايش فى اوربا او اى دولة خارج الوطن العربى يعمل فك الحماية وبعدين يفك ضغط البرنامج ويضغطه مرة اخرى بكل اضافاته ويرفعهولنا بصيغة رار من غير باسورد وله جزيل الشكر
الرابط فى المرفقات
DVBviewer Pro 4.1.1.1 + plugins
DVBViewer allows you to experience Digital TV on your PC. With a proper DVB card you can enter the world of digital entertainment and experience high quality, incredibly sharp TV pictures and near CD quality radio!
What features does DVBViewer provide?
It provides all basic functions you need to enjoy digital television and radio programs. In addition, DVBViewer offers you a wide range of advanced features such as Teletext, Electronic Programming Guide, Remote Control support and enhanced recording capabilities which enable you to record your favourite shows on hard-disc, edit them or share them with your friends.
Which features make it unique?
DVBViewer contains functions which are groundbreaking : It was the first program with a so called DesktopTV mode and in its category the only product which offers AC-3 and Timeshifting features. It is even possible to handle more than one DVB device at the same time. Further on the multimedia skills of the DVBViewer do not need to hide behind other mediacenters. From playing multimedia contents up to receiving RSS newsfeeds, weather data, everything is possible.
All the extras from the dvbviewer member's area.
These are:
App
ChannelList Editor1.5.1
DVBTaskScheduler_v2.2.3
httpServer (web interface) 1.5.0
TransEdit Scanner & Editor_3_3_3
TransEdit_Manual
Beta
Avermedia Remote Control Plugin
DVBViewer Recording Service
DVBViewer Starter 1.9.9 Beta (for DVBViewerPro 3.6+)
IPTV Transedit Test 3.2.2 (only for DVB over IP!)
MySkype_Beta2
MySkype_Beta3
TVInfo Import 1.2.1
XMLTV Importer (Beta for DVBV 3.2)
Input Plugins
firedtvremote1.1.1 (for DVBViewerPro 3.6+)
Geniatech_Remote
MCE Remote Plugin
Technotrend Remote Plugin 1.1.1a (DVBViewerPro 3.6+)
Twinhan USB Remote
X10remote1.1.1 (DVBViewerPro 3.6+)
Plugins
AudioRecorder
DVBViewer_Filter_3_4_0
Girder Control Plugin 1.0 (for DVBV 3.1)
Girder Control Plugin 1.1 (for DVBV 3.2.5+)
jaLCD3x (for DVBViewer 3.2+)
Libfaad2Wrapper_1_1_3
mhp_carousel
osdsleeptimer1.1
PostProcessor_Plugin_2_1_0
Radlight Audio Selection Filter
SatcoDX_Import_Plugins
Teletext_Fonts
TV-Info Importplugin 1.1.6 (DVBViewer 3.9.x)
TV Genial + CMDline 1.2
VideoRec_3_4_4_2
VideoRec_Manual
Skins
04_blackmoon(english)1.0
07_d-remix(english)1.0
08_fusion(english)1.2
09_blackfusion(english)1.0
dvbvskinsokeh
froschs_osdskin
GUI_Skin_Gate_(DEU_&_ENG)
minium(english)1.1
NewDef
NewDefHD
okeh2
okeh2ger
Skins for DVBViewerPro by Technofriend
tvlogosetup
Weather-Icon-Set_Unity
Weather Images for the HTPC
XBox Mediacenter OSD Skin
XBox Skin 16 9 (HD)
Tools
Channel Shortcutter_1_3
Commandline Starter Plugin
DVBViewer Recording Properties (Vista+ 32bit only)
File Property Copier 1.2
H-264_ParamReader_1_3_0
OSD-Menu Editor 1.1 for DVBViewer 3.9.2+
RadLight Filter Manager 1.6
RDSExtractor_v1.1.2
Reset Technisat cards (for win2k, xp +)
SkinCompiler
TSPlayer_2_1_1
TSPlayer_Manual
TVInfo Import 1.2.0.1
WOL for DVBViewer
الرابط فى المرفقات
