SimOSD Module 1.2 fulll for dvbdream اصدار محسن ورائع ومعلومات كاملة عنه
killkill
بسم الله الرحمن الرحيم
طبعا جميعنا نعرف osd ووظيفته وهذا اخر اصدار منه للبرنامج الرائع dvbdream
SimOSD v1.2 What`s New v. 1.2 (28.02.2007)
- Added a mouse and keyboard controllable OSD Channel List!!! - You can now display a channel list on OSD allowing you to switch channels from that list Info OSD Channel List is displayed b
وللمعلومات عن هذاه الاضافة ووظيفتها اقرا التالي
OSD Channel List is displayed by pressing the ESC Key on keyboard or by pressing the C icon on top-left part of the screen.
List Navigation:
Keyboard:
* F1 & F2 to go Up or Down the list
* SPACE to switch to channel
Mouse:
* 4 arrow-buttons (bottom-left of the OSD Channel List panel) allow you to sroll Up or Down the list (Scroll by Line or Scroll by Page)
* Left-Button: click on a channel to switch to
Channel Groups:
General, Favorites & Remote lists correspond to the 3 main categories used by DVBDream. Using them with SimOSD is quite different from using them from DVBDream.
General & Remote groups only display TV or Radio, you can select type to display using the TV & Radio buttons on bottom-left of OSD Channel List panel.
Favorites group display all TV and Radio channel included in this group.
Sat Name button, does not allow to switch sat. It's only used to display current sat name.
Close OSD Channel List:
Keyboard: press ESC key when OSD Channel List is displayed
Mouse : Click on the C icon located on top-left of the screen or on the red button located on top-right of the OSD Channel List panel (comes from Vista).
Font type & size:
Font type & size used by SimOSD are the same as DVBDream's one. You can select them in DD by clicking on Options - Preferences and selecting Localization. Font used by DD to display OSD can be defined by clicking on the EPG Now/Next Font button.
Only Font name and preferred language setting of DD are used by SimOSD. Do not forget to use "Always switch to preferred language" option of DD to avoid spécific Charset
issues.
To increase or decrease font size in the OSD Channel List you can click on the "-" & "+" button located in the top-right of the OSD Channel List panel.
Channel List settings:
Some few settings can be done from the SimOSD window (Module - SimOSD in DD)
The 3 C and Arrows icons located on the top-left of the screen auto-hide themselves when no mouse gesture has been detected during a specified delay, this delay can be set from the window shown beside. To unhide them, you just have to move your mouse over more than 20 screen pixels.
EPG Info display modifications
With this new release, EPG Now & Next won't anymore be displayed when mouse cursor is moved to the top of the screen.
From now on, EPG Now & Next can be displayed by clicking on Arrow-icons located on the top-left of the screen. Left arrow for EPG Now and Right arrow for EPG Next. When EPG panel is displayed, a click on the same icon make it disappear.
EPG font type and size can be selected from DVBDream's Options the way it has been done for Channel List, but only font size lower or egal to 22 are handled.​
وتم اصلاح مشكلة epg التي يعاني منها dvbdream مع هذا الاصدار
ولا تنسوني من صالح دعائكم الطيب
a19zco
اخوي لدي مشكلة التقطيع عند وقت ظهور SimOSD
وكيف اضبط زر OK في الريموت لعرض قائمة القنوات على الشاشة؟؟
noble911
اضافة قوية جدا للدريم
جزاك الله خير
ضروري يتم تثبيت الموضوع لتعم الفائدة
علي كراش
مشكور ......................... .....................مشكو ر............
....مشكور... ......مشكور.......... .............مشكور.........مشكور.....
..مشكور..... ..........مشكور...... .........مشكور............... مشكور.....
..مشكور..... ....................مشكور ......................... .....مشكور.....
....مشكور... ......................... ......................... .....مشكور.......
......مشكور. ......................... ......................... ...مشكور.....
.........مشكور....................... ..... .................... مشكور.......
............ مشكور.................... ....................مشكور ......
............ ...مشكور................. ................مشكور.........
............ ......مشكور.............. ............مشكور........
............ .........مشكور........... .......مشكور...........
............ ............مشكور.........مشكور....
killkill
اسف على السؤال
لوكن ما هى فائدة osd>?
لا اخي لا داعي للاعتذار من حقك تسال
osd هو عبارة عن اضافة تضاف لبرنامج العرض وكل برنامج عرض له osd خاص به ويقوم بعرض قائمة القنوات بطريقة احترافية الى جانب معلومات كب قناة واحيانا يقوم بدعم خاصية epg اي دليل البرامج الالكتروني ويسهل عملية التحكم بالقنوات والصوت وما الى ذلك بواسطة الريموت
totti10it
الف شكر اخى kill kill
على اهتمامك
ahmadolabi
طيب اخي ممكن نتكمل معروفك معنا وتدلنا كيف نركب الملف عالبرنامج ونقدر نستفيد منه ولك جزيل الشكر
killkill
اكيد اخي مافي ابسط من هيك بعد تحميل الملف وفك الضغط ينتج لك ملف امتداده mod انقله الى مجلد module داخل مجلد الدريم دي في بي وشغل البرنامج راح يشتغل معاك وانت راح تكتشف الباقي بنفسك لانه جدا واضح وبسيط وممتع ولو وقف معاك انت تامر اعملك شرح مصور لكل صغيرة وكبيرة في الاصافة اخوك
alhwitat
مشكور
السلام عليكم ورحمة الله وبركاته
التحديث الجديد بتاريخ 12-6-2010
تم اضافة باقة الجزيرة الرياضية الاضافية على النيل سات
