didou
Mantis device 0.3 For DVB Dream
What's In this version:
* [v0.3] Added small delay to make DiSEqC sending more reliable
* added small dialog that says card is tuning instead of just freezing up DD
* [v0.2] Fixed bug on 1.1.1.900 drivers, added some driver info to "Device option" message box
* [v0.1] First version
Mantis device
What works:
* Tuning both DVB-S and DVB-S2 signals except 16/32APSK (see below)
* Raw DiSEqC, Tone/Data burst should work too (untested)
* And all other normal stuff you want your card to do
What doesn't work:
* 16APSK - There is no way how to tell card you want to use any specific modulation. It completely ignores all BDA inner/outer FEC values. Windows device driver uses same routines as Linux one (google it if you want to see source code) and it should be able to autodetect 16APSK signals. However this fails for some reason and after few seconds
with signal (but no decoded stream data) it fails. This is probably bug in the driver and hopefully will be resolved as this modulation gets more widely used.
* CI slot - I don't have CI slot for this card and actual programming looks rather ugly, so I'm skipping on this one
* Handling more than one Mantis card on single PC (you can have more BDA cards, just not more Mantis chipset ones).I can fix this in future if someone really needs it.
Supported Cards:
* Technisat SkyStar HD2
* Azurewave AD-SP400 CI
* TerraTec Cinergy S2 PCI HD CI
* And other cards with Mantis chipset
*This device is only for DVB-S/S2 cards. It doesn't support ATSC or DVB-T cards with this chipset.
thumb:
: من هنـــــــــــــــــــــــــــــــا
Mantis device
What works:
What doesn't work:
Supported Cards:
thumb:
