Need for Speed
Hot Pursuit
ISO 7.8 GB
Screen Shots
System requirements
"Operating system: Windows XP (SP3) / Vista / 7;
"Processor: Intel Core 2 Duo (1,8 GHz) or AMD Athlon X2 1964 (2.4 GHz);
"Memory: 1,5 GB (for XP) / 2 GB (for Vista / 7);
"Video: 256 MB VRAM compatible with DirectX 9.0c, with support for Shader 3.0;
Supported video cards: ATI Radeon series X1950, HD 2000/3000/4000/5000; NVIDIA GeForce 7 series (7600 or higher) / 8/9/100/200.
"Hard disk: 8 GB;
VIDEO CARD SUPPORT
Need for Speed™ Hot Pursuit only officially supports Direct3D for certain 3D
accelerator devices. While other devices running Direct3D may function in Need
for Speed™ Hot Pursuit, their behavior cannot be predicted and may lead to an
unstable PC Environment.
The following major video card chipsets are supported:
ATI
Radeon X1950 series
Radeon HD 2400 series
Radeon HD 2600 series
Radeon HD 2900 series
Radeon HD 3400 series
Radeon HD 3600 series
Radeon HD 3800 series
Radeon HD 4800 series
Radeon HD 5000 series
NVIDIA
GeForce 7 series (7600 or better)
GeForce 8 series
GeForce 9 series
GeForce 200 series
GeForce 300 series
GeForce 400 series
***NOTE: Laptop versions of these chipsets may work, but are not officially
supported. NVIDIA GeForce MX series not supported.
Do a Check whether the game will work on your PC or not
Check the games requirement by this SITE
اللعبة عبارة عن ملف ISO
يتم التسطيب عن طريق برنامج DAEMON Tools
DAEMON Tools Pro
Direct X
PhysX AG
PhysX NV
Crack
DuckLoad
http://zero10.net/644999
HotFile
http://zero10.net/645000
C:\Program Files\Electronic Arts\Need for Speed(TM) Hot Pursuit
Links , 200 MB
Download Now
